Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Jay - God of Honeywell thermostats ... I need help again (progamming)
Old 02-14-13, 01:55 PM
You helped me install a VisionPro with Truesteam successfully - thank you !!!
At the moment, however, the fan does not respond to "on" or "circ" from the panel. The humidifier works fine, heat/fan works fine ...
In "test" mode the fan operates as it should. I have a basic Lennox heat pump with the basic airhandler and outdoor temp sensor.
I confess to "messing" with the settings (I generally try to improve things until they no longer work properly) Any recriminations you feel the urge to throw my way are deserved
Any programming tips you can throw my way will be sincerely appreciated!
Old 02-14-13, 06:38 PM
Jay11J's Avatar
Sounds like the t-stat may be an issue or the EIM that is not getting the signal from it to turn on the fan from the "FAN setting"
What settings did you change/mess with?
Old 02-15-13, 08:53 AM
Greetings Jay. I went through the complete set-up sequence again this morning, using your previously advised settings - guess what? Seems to be functionning properly once again !!!
I sincerely thank you for your patience (and your sharing of your considerable knowledge)!
Old 02-15-13, 07:36 PM
Jay11J's Avatar
Glad to hear you got it back up and running!
now don't play with the settings anymore!
