Nest Install Wiring Help
Old 03-12-13, 07:34 PM
I recently replaced a older honeywell thermostat with a 2nd Gen Nest unit. I read around in the forum and Nest Support to hopefully of installed it correctly. The heat turns on fine and it seems to function properly, however I am not sure I connected everything correctly. I have a 8 wire cable coming through and this was the original connections:
It is electrical heat/cooling. I am not sure I connected all the right wires from what was marked on the last thermostat to the new Nest, being that some were not labeled on the Nest such as X and just having R and not Rc/Rh etc.
Here is the Nest hooked up.
Any help or tips would be greatly appreciated.
Old 03-12-13, 08:09 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
looks fine to me............
