Installing RTH6450D on Rudd UPNE-036JAZ
Old 04-22-13, 07:26 PM
Hello,
I am trying to install a new programmable thermostat (Honeywell RTH6450D) to replace my existing non-programmable(Honeywell T8411R). The unit is a Rudd UPNE-036JAZ. Please see photo for current wiring. I am unsure where to put W1, W2, and E on the new thermostat.
Thank you.
Old 04-23-13, 03:27 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
First, read your manual, especially the advanced installation section
SHUT OFF THE FURNACE/AIR HANDLER POWER AT THE BREAKER
USE heat pump terminal designations
R = R
C = not used
G = G
W2 = AUX
E = E
B = O/B
W1 & Y = Y
The thermostat must be setup for HP WITH aux heat and O/B for use with heating.
Old 04-23-13, 04:57 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
1 = 5 ( heat pump with Aux heat)
2 = 1 (energize reversing valve for heating)
Old 04-23-13, 07:42 PM
R = R
C = not used
G = G
W2 = AUX
E = E
B = O/B
W1 & Y = Y
Read more: http://www.doityourself.com/forum/th...#ixzz2RLR2XeW9
Thank you for the reply! I've read the manual, and pretty much had all of the connections figured out except for the W2 and E. There is only 1 slot for these...do I just put both wires in the same slot?
Old 04-23-13, 07:47 PM
hvactechfw's Avatar
yes, both in the same slot
