Question about new t-stat and jumpered wires
Old 08-22-13, 09:02 AM
A
Received 1 Vote on 1 Post
I have a heatpump system, two stage compressor, variable speed furnace and an arzel zoning system. The old t-stat is a Robertshaw 9620. The one I want to try to install is a Nest. Here are the wires I have:
Y2
Y1
E
G
W2
O
C
R
I don't have the colors of them handy, but these are the ones hooked up to the terminals in teh robertshaw. The problem is that I have an additional jumper between E and W2. Why? Nest says NOT to jumper it on the Nest as its all internal, but im curious why mine is jumpered.
Also, why do I only have an O and not and O AND B?
Old 08-23-13, 08:55 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
Your old stat requires the jumper between Aux and E because it is not internally jumpered.
O energizes the reversing valve of a heat pump for cooling and B is to reversing it for heat.
Rheem, Ruud and weatherking use B and almost every other brand uses O.
