Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Need help wiring Honeywell th8320u1008 to carrier infinity 80 gas furnace
Old 08-24-13, 09:24 AM
K
Painters removed the honeywell thermostat before painting, leaving me to figure out how to put it back on the wall. Only three wires are coming from the wall - red, green , and white. Which screws should I connect those three wires to on the thermostat?
I note that the thermostat has different markings for "heat pump" and "conventional". There is a jumper connecting RC and R. I tried connecting the wires to G, W, and R on the conventional column (conventional W = heat pump O/B) and the result was the furnace came on full blast and wouldn't turn off no matter what I did with the thermostat settings.
Any help appreciated!
Thanks-
Old 08-24-13, 10:25 AM
G
Received 2 Votes on 2 Posts
Try red to R/RC, green to G, and white to C.
Old 08-24-13, 07:49 PM
Received 1,610 Votes on 1,482 Posts
Welcome to the forums.
Close......try:
Red - R/RC - hot
Green - G - fan
White - W - heat
If you look inside your furnace..... you should see those same three wires. Those wires will match the letters at that end also.
