RTH7600D "170" setting
Old 11-14-13, 02:34 PM
C
I'm trying to tweak my RTH7600. I understand the 240 "cycles per hour" setting. What I don't understand is the "170" setting. How does the thermostat behave based on this setting? I have a hydronic system ("hot water" boiler). What does the thermostat do differently on this setting from other settings?
Thanks!
Old 11-15-13, 06:43 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
It looks self explanatory. A heat pump energizes the compressor terminal for heating and cooling, an electric heat setting energizes the fan circuit for heating as well as cooling, gas heat energizes the fan circuit for cooling. Your application will not energize a fan circuit.
Old 12-18-13, 03:41 PM
C
I agree. The reason I ask is that I can't see the subtle difference between the 3 and 5 setting. Honeywell CS was not helpful.
Old 12-18-13, 06:16 PM
Houston204's Avatar
I would set option 170 to 3 for that application.
Old 12-18-13, 06:23 PM
C
ok, thanks. I was interpreting "3" as possibly forced hot air, with "5" as FHW. Could "5" be radiant heat?
Old 12-18-13, 07:32 PM
Houston204's Avatar
I meant 5.
5 is also series 20 with higher end Honeywell stats. I see no mention of 3 wire valves in this stat manual.
Old 12-19-13, 02:45 AM
C
Ok, thanks for the follow-up. I checked my email from Honeywell and they said to choose 5, but I could pick 3 if the system was short-cycling. I asked for more information/clarification and all I got was some vague commentary!
I will set to 5. Much appreciated.
ps - I'm using a CPH (240) setting of 3. That seems to be the consensus in other threads in this forum.
