Wifi Thermostat Question
Old 11-21-13, 07:50 AM
Looking for a Wifi thermostat that is programmable to continue calling for heat past it's degree setting. IE, if set for 70, heat is called until 72, 73, etc. Any options?
Old 11-21-13, 08:48 PM
Received 1,472 Votes on 1,360 Posts
Ummmm..... I'm a little lost here. Why wouldn't you just set the thermostat to the temperature you wanted. If you want 72f just set it to 72f.
Old 11-22-13, 06:24 AM
Found out it has to do with the thermostat's cycle rate. This is programmable based on the heating system you have. My existing thermostats don't have this feature. I spent a few hours reading the honeywell WIFI 9000 settings and decided to buy 2!
