Thermostat install and overloading the furnace C terminal?
Old 11-24-13, 06:48 AM
A
Hi -
I am installing a Honeywell WIFI thermostat and don't have a C wire on my current thermostat. I plan to substitute the existing G wire for the C wire. After the rewire, my C terminal on the furnace will have 3 wires connected: 1.) ac unit, 2.) thermostat, and 3.) jumper wire connecting C and Y. Is that OK or am I overloading the C terminal? Thanks.
Old 11-24-13, 08:36 AM
Received 2,954 Votes on 2,665 Posts
Welcome to the forums.
The C connection or wire is the common connection point. You can't overload it. You may get several wires on the same terminal but that is ok.
The transformer that supplies the 24vac (C and R) can be overloaded if too many devices are put on it. You should be ok with just the WiFi thermostat.
Old 12-08-13, 06:08 AM
W,G and Y are all C sides of the system TR at the stat subbase ....never heard of jumping Y to C just a comment but if it has always been like that ..go with it
Old 09-18-14, 08:08 PM
C
C terminal
The y terminal is for cooling
Old 09-18-14, 09:44 PM
Thanks for the info..... the OP hasn't been back since he posted this.
