Thermostat wiring question
Old 12-08-13, 07:00 AM
R
I'm replacing the thermostat for my ceiling heat in the downstairs. I have a Lux TCH 15a. My question is which terminals do I hook the wires to? I have 1red & 1white wire coming from the junction box. The thermostat has a terminal block with G Y RC RH W. There is a jumper wire from RC to RH. The wiring diagram says W is gas valve or heater & RH is system xfmr (with jumper still on) can anyone point me in the right direction? Thanks!
Old 12-08-13, 08:29 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
Ceiling heat is typically high voltage, how big are the wires at the junction box? The thermostat you have is for low voltage.
Old 12-08-13, 02:47 PM
R
They are tiny wires 18 or 20 gauge?
Old 12-08-13, 03:11 PM
Received 4,139 Upvotes on 3,717 Posts
The jumper can remain on the two R terminals.
Red goes to Rc/Rh
White goes to W
