Thermostat Recommendation with remote sensor
Old 12-08-13, 08:44 AM
2
Currently have a white rogers 1F82-261 stat hooked up to furnace and heat pump. My issue is our gas fireplace is close to the thermostat so remote areas of the 1st floor get cold if the fireplace is on. I do not believe I can add a remote sensor to the 1F82-261. Any suggestions on a reliable thermostat/remote sensor to install? With regard to installation, is it as simple as connecting the wires to the same terminals as the 1F82-261 or does it get more complicated?
Old 12-08-13, 10:58 AM
Houston204's Avatar
Received 38 Votes on 34 Posts
http://www.emersonclimate.com/Docume.../0037-6175.pdf
Honeywell offers some choices for wireless sensor/ thermostat combinations for a multistage heat pump.
