Adjusting a Cadet TH410 Thermostat
Old 01-04-14, 09:20 AM
V
Have a wall mount TH4110 and the system was not reaching set temp, pulled faceplate off and it appears as if the arm on the back of the rotary knob that goes into a trough was not moving the arm that goes full hot to off to the full hot position (if i am speaking correctly) is there a way to adjust this moving arm to ensure the Stat goes full hot and does not stop short. (have i confused you yet)?
Old 01-04-14, 10:18 AM
Received 4,153 Upvotes on 3,730 Posts
Yup.... I'm confused. A picture would sure be helpful. http://www.doityourself.com/forum/el...-pictures.html
