Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Installed new package unit with Honeywell pro 3000 stat. NEED HELP!!!
Old 01-17-14, 08:57 PM
Ok i installed a new AIREASE self contained package unit and I need help the the stat. It is a 3 ton unit (rphp13a36p) I also installed a 15 kw heat strip inside the unit. I have those wires correct. I hooked all the color coded wires like the instructions says but I can't figure out the thermostat. The heat strip comes on but I cant the heatpump to come on. Im sure its just a wire in the wrong place. The thermostat reads E Aux Y G O L R B C. Thats 2heat/1 cool. When I turn the stat to heat only the aux heat comes one but the compressor of fan never comes on. I have my stat wires in the unit color coded to those same wires and I have my white going to the aux and my blue to the C. Is this correct? Thanks for your help, WES
Old 01-17-14, 09:16 PM
Houston204's Avatar
Received 14 Votes on 11 Posts
http://www.airease.com/_/pdfs/specs/..._Tech_Spec.pdf
http://www.forwardthinking.honeywell...ll/50_9271.pdf
Do you have the TH3210 for heat pumps or the TH3110 that will not support a heat pump with Aux heat?
Old 01-18-14, 05:56 AM
I do have the TH3210 thermostat.
Old 01-18-14, 07:31 AM
can you tell me if the blue wire and the white wire are in the right place and why isn't my compressor coming on?
Old 01-18-14, 08:05 AM
Houston204's Avatar
Post your terminal = wire color combination at the stat.
Post the stat wire color= heat pump wire (or terminal) combination at the heat pump.
Old 01-18-14, 04:32 PM
Terminal reads : E Aux Y G O L R B C
C 24 vac common
B Changeover valve in heating
R power
L output when set to em. heat
O changeover in cooling
G fan relay
Y comp. contractor
Aux Aux heat relay
E emergency heat relay
I have a white going to aux. Y=y red=r g= green orange=O blue=C. Those are the same colors at the unit where the stat wire hooks up and thats where I have them hooked up on the stat. Should I have a jumper.
Old 01-18-14, 04:56 PM
Old 01-18-14, 05:54 PM
Houston204's Avatar
Did you have the power off when you installed the stat?
Are we getting 24 volts AC to the yellow wire with a heating demand?
http://www.airease.com/_/pdfs/instal...13_Install.pdf
Any trouble codes displayed with a heating demand?
Old 01-20-14, 06:32 AM
I had over off when installing stat. I didn't test for 24 volts. Couldn't find my dvom. Ac red and green are showing no codes.
