Thermostat wiring
Old 01-23-14, 06:30 AM
W
Thermostat wiring
I have a manufactured home, gas heat, electric A/C, electronic thermostat. Thermostat has gone blank, no power to it, checked all circuit breakers, they are good. Is circuit breaker for thermostat outside in the furnace/AC unit?
Old 01-23-14, 07:29 AM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
Does the thermostat need batteries ?
Many package units have a blade type automotive low voltage fuse to protect the 24 volt transformer from damage when the stat wire is damaged causing a short.
If the fuse is popped inspect the wire for damage before replacing the fuse.
Old 01-23-14, 07:39 AM
W
I don't see any battery; input power is low voltage so must come from a transformer somewhere.
