T-stat replacement help
Old 01-24-14, 10:11 AM
I need some help with a T-stat replacement. I have an old White Rogers thermostat that I'm replacing with a Honeywell WiFi and I need a c wire
The old thermostat has the following:
Connection / Wire
R / Red
W / White
Y / Yellow
G / Green
N/A / Blue
The blue wire not connected to the T-stat or furnance.
At the furnace board (Bryant 359AAV) I have:
Furnace / Wire from T-Stat / Wire from A/C
R / Red / N/A
C / N/A / Red
W / White / N/A
Y / Yellow / Yellow
G / Green / N/A
HUM24VAC / N/A / N/A
My plan is to connect the extra blue wire to the C terminal on the new T-stat. My confusion is at the control board.. should it connect to the C terminal or the Hum 24VAC terminal?
Thanks for the help
~Staudie
Old 01-24-14, 12:44 PM
Houston204's Avatar
Received 18 Votes on 15 Posts
Connect blue to the furnace C terminal and stat C terminal.
