honeywell rthl 3550 and a goodman cple30-1
Old 01-25-14, 08:47 PM
i am trying to install the new honeywell tstat. the old tstat was a white rodgers model 1f73.
i have included a picture of the old one with the wires still connected. my question is where do i put the wires in the new tstat. i have included a pic of that one also.
what should i use in the programming? i took ac/heating in trade school 25 years ago i graduated in the top 3%. now i dont know any of this new stuff. please help.
Old 01-26-14, 12:45 AM
Received 1,509 Votes on 1,396 Posts
Welcome to the forums.
On the new thermostat you go by the bottom designations since you have a heat pump system.
The orange wire belongs on the O/B terminal. You need to set the thermostat to a heat pump system.
I believe the other wires are correct and you can just tape the blue wire off.
Your model number isn't complete but I'm assuming you have electric re-heat coils.
The forum pros will stop by and give you a hand fine tuning your settings.
Old 01-26-14, 09:02 AM
ok thank you,
the only problem that i have is the heat just will not shut off. other then that everything seems to be working fine.
Old 02-06-14, 09:55 AM
ok as you can see the e/w and w2 is jumped together. the way it looks on the new thermostat the o/b is the same as the w2. do i put put both the white and orange together?
Old 02-06-14, 10:15 AM
what kind of thermostat do i need for this unit?
Old 02-06-14, 12:24 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
Your new thermostat will work with your system. Connect the orange wire to the O/B terminal and connect the white wire to the aux /E terminal.
configure the thermostat for heat pump with auxiliary heat.
Old 03-17-14, 08:50 AM
B
My old thermostat has 7 wires. installing Honeywell RTHL3550
My old thermostat has 7 wires. It's and old millee mercury thermostat.
Yellow to Y
Green to G
Red to R
Orange to O
White to W2
Blue to E
Brown to C
They new honeywell has
L
Aux/e
G
O/B
NOT USED
Y
R
where does the white wire go? Where does the blue go? Where does the brown go?
Old 03-17-14, 03:38 PM
Houston204's Avatar
Connect blue and white to the Aux/E terminal.
Tape off the brown wire since your new stat doesn't support common and runs off of batteries.
Configure for heat pump with Aux heat.
(1 = 5)
Verify that the O/B terminal is configure to be O (energize reversing valve to cool).
(2 = 0)
Old 03-17-14, 07:27 PM
B
Thanks so much. Will give it a try tomorrow.
Just wondering, could the brown wire you said to tape off, could I just put it in the Not Used terminal or just tape it off?
Old 03-17-14, 08:20 PM
No.... that wire cannot be connected anywhere to that thermostat without causing a short.
Just tape it off and tuck it in the wall.
