Install new Honeywell Thermostat (C wire issue)
Old 01-26-14, 10:54 AM
I am looking to upgrade my current thermostat to a new Honeywell wifi thermostat (Model # RTH6580WF). My current thermostat has 4 wires:
As you can see I do not have the C wire required for the newer thermostat. I am able to run a new wire to use as the C wire with no problem, but I am unsure of where to connect it in the terminal block in the outside unit. I have 2 C terminals but both are in use as you can see in the following pic:
Also, I was able to find the wiring diagram for my model (Rheem RRKA Series):
http://www.rheem.com/documents/rrka-...ication-sheets (Page 27)
Any help would be greatly appreciated. I tried to include as much info as possible but please let me know if I need to post any additional pics or info/ Thanks.
Old 01-26-14, 11:00 AM
Received 1,598 Votes on 1,473 Posts
Welcome to the forums.
In that unit..... the common is also connected to the metal case. You can use the screw right next to the two C terminals to connect to.
Old 01-26-14, 02:40 PM
Pulled a new wire, attached to that common ground and its working like a charm. Thanks so much!
