Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Honeywell Wifi Thermostat - Question regarding the "C" common wire.
Old 02-02-14, 08:02 PM
R
Hi,
I purchased a honeywell wifi thermostat. I am planning on hooking up 4 wifi thermostats to the 4 zones of heat I have in my home. I am using Taco pumps & a controller. I see two terminals, one for common, one for 24vac - On the top right of the board.
1. Which one should I be using for the thermostat "C"?
2. Can my controller (ARM-6P) support 4 total honeywell wifi thermostats sharing the same "C" wire for all four units? (Is there enough power to keep all thermostats running)?
3. Is there an issue having 4 wifi thermostats running in the same home/network?
Thanks,
Rich
Old 02-02-14, 09:16 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
I'd pick up a 75VA transformer and connect it to RC and C on the new stats.
Then connect RH and W to the zone control board.
Remove the jumper between Rh and R at the new stats.
Old 02-03-14, 07:13 AM
R
Hi,
So I have a strange situation which might make that harder.
I had a 4 zone air conditioner system installed this summer. So I have one set of wires heading to the attic to an air handler, then another set of wires heading to the basement (heat).
I thought I could just take one spare wire from the heat (not being used) & just pop it onto the common. Can I just use one wire or do I need to use two?
Ideally, I would just take a red wire (wrapped in a coil in photo), uncoil it and pop it onto one of those two leads - so I was wondering which one I can use?
Thanks,
Rich
Old 02-03-14, 04:47 PM
Houston204's Avatar
I think that would cook your transformer. I don't recommend it.
