Home Thermostat Temperatures
Old 02-06-14, 06:24 AM
0
I have a Honeywell Digital non-programmable wall heating only thermostat Model T8775A that is connected to 1 zone of my infloor radiant heating system. I noticed that if I set a desired temperature the temperature is reached but overnight when I get up it is usuall about 1.5 degrees lower thane the set desired temperature. Do most thermostats work with a 1-2 degree difference before starting up again.
Old 02-06-14, 08:17 PM
Received 4,084 Upvotes on 3,667 Posts
The accuracy listed for that thermostat is +/-1 degree so yes it's normal to see a difference like that.
