some help needed.....
Old 02-06-14, 06:19 PM
P
So the old thermostat only has two wires going directly to the primary control in the basement. I ran a 5 wire down to the furnace, now before i hook it i want to make sure im set.
So my furnace transformer has R C Y G W
the picture on my schematic shows Y G Rc W Rh for the thermostat.
On the diagram it shows W and Rh connected directly to the primary control.
Is this diagram just outdated?
I was going to R to R(which shows Rc on my diagram; G to G, Y to Y; and then W and the other R to the control? Thats where I get confused
Thanks
Size:  17.7 KBName:  wiring2.jpg
Size:  18.8 KBName:  wiring.jpg
Old 02-06-14, 06:28 PM
Received 1,041 Votes on 965 Posts
Do you have an air conditioning system that was added after the oil fired furnace ?
If that schematic diagram in the next post up is what you have...... you'll need 6 wires for the hookup.
Old 02-06-14, 06:50 PM
P
no ac...really think i need 6? It only has two now.
Old 02-06-14, 07:02 PM
No.... you're ok since you don't have A/C.
You don't need a Y connection.
You'll need C, G, and Rc from the fan center.
And you'll need W and Rh. (existing two wires that go to TT terminasl)
Old 02-07-14, 04:14 AM
P
Ok I an removing the jumper on the thermostat? R to rc
Old 02-07-14, 05:23 PM
P
Ok a better question
from my furnace to the thermostat
G to G
C to C
R to ?r?
Thermostat
RH and W to the ignition where they go now.
My only question now is if I use the one and two slots for r and rh and they are jumpered will that matter?
Old 02-07-14, 05:37 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
G to G
C to C
R to Rc
T to Rh
2nd T to W
Remove the jumper.
Old 02-09-14, 11:34 AM
P
THANKS! It all worked perfect....very nice
Old 02-10-14, 05:56 PM
Houston204's Avatar
That is great news.
