Honeywell RTH6500WF and an OLD Lennox unit
Old 03-02-14, 01:59 PM
I have a very old Lennox A/C - Gas heat unit that I would like to have controlled by a brand new Honeywell Thermostat (RTH6500WF). I can not find any model numbers on the unit. Of course, the problem is the "C" wire. I have an extra blue the bundle that I can use.... but.. I don't know where to connect it at the unit as the terminals are only marked with numbers instead of letters. The old thermostat has the standard 4 wires (R,B,G,W) and are attached to the appropriately marked terminals. At the unit, they are attached as follows:
R - 1
G - 2
Y - 4
and then the white one goes to what appears to be a relay box (which is marked 24V on top)
My question is where can I attach the unit end of my blue wire to make it a "C"?
Old 03-02-14, 03:13 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
The wiring diagram should be on the inside of one of the blower panels on your furnace.
