Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Trane Baysens019B switch to honeywell wifi t stat help with wiring thanks
Old 03-29-14, 10:35 AM
W
I have the following wires on terminal
that goes to Baysens019B t'stat
7-white wire
8-yellow wire
9-blue wire
10-brown wire
11-black
12-purple
14-red
16-yellow
17-green
I have honeywell wifi t'stat with
RC
R
W O/B
Y
G
C
L
E/AUX
K
How do I wire
thanks
Old 03-29-14, 11:11 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
http://www.google.com/url?sa=t&rct=j...63808443,d.cWc
You can't install your new stat unless your Trane unit also has conventional terminals or (if the ac unit is very old) you get an adapter board.
Post the model number of your ac unit.
Old 03-29-14, 01:35 PM
W
Model YCD480. Next to terminal board is an board with r,rc,y,g,l but no wire to it.
Old 03-29-14, 01:55 PM
Houston204's Avatar
http://www.trane.com/download/equipm...rc006en_r6.pdf
You would need to move the wires from the numbered terminals to the lettered terminals at the package unit as well.
Old 04-03-14, 01:06 PM
W
sorry no r,rh etc
Model YCD480. Next to terminal board is an board with 1,2,3,4,5 but no wire to it.
Old 04-03-14, 09:47 PM
Houston204's Avatar
After Removing the large panel at the compressor section the numbered low voltage connections can be seen. It is usually necessary to remove a second smaller panel in the upper portion to see the control board.
I have not seen a board without both types of connections for many years.
