Wiring for fan only
Old 05-13-14, 09:24 AM
R
Wiring for fan only
I have a lennox g50df 24a gas furnace with a honeywell rth111 series thermostat. The wiring was only w and r furnace works no problem. I wanted to wire it so i can use the fan only in the summer. Looked on the web found should run wire from terminal g on both which i did but fan does not run what other leads do i need to wire or will this not work. Thanks
Old 05-13-14, 10:26 AM
Received 1,505 Votes on 1,393 Posts
Welcome to the forums.
Did you make sure that the R wire is connected to R at both ends ?
With just a two wire setup..... the order of W and R didn't make a difference. Now with a third wire in use.... it's important.
Old 05-13-14, 11:47 AM
R
i checked again yes terminal r w g same on both ends
Old 05-13-14, 04:58 PM
At the furnace end..... try a jumper between R and G terminals. See what happens then.
You can use any wire and just touch it to the contacts.... it's low voltage there.
Old 05-14-14, 05:39 AM
Geochurchi's Avatar
Received 91 Votes on 86 Posts
Have checked the jumper on the back of the stat?
http://www.honeywellstore.com/store/...ion-manual.pdf
