Source 1 CTS Thermostat Wire Issues
Old 05-17-14, 12:54 PM
H
I bought a Source 1 Touch Screen Thermostat(Source 1 CTS-Series Color Touchscreen Thermostats) and I can't get it to turn on. My old thermostat ran off battery's but the new one doesn't. So from my understanding it needs a 24vac common hookup. My question to you is how do I hook up a 24vac common line? Below are pictures of what I have so far. Also in the picture of the wall mount you will see a yellow wire not going to anything, the store didn't have 18/4 wire in stock so I got 18/5 wire. So the yellow wire doesn't go to anything currently. Thanks for your help.
(The Furnace)
(The Wire Hookup)
(Wall Mount)
Old 05-17-14, 01:47 PM
Received 1,619 Votes on 1,491 Posts
Welcome to the forums.
Did you follow original color code ?
Are the letters I put on terminal strip correct ?
Normal wiring color code
G = green
Y = yellow
W = white
R = red
C = blue
Old 05-17-14, 01:51 PM
H
They are but the G is actually "GC" and the H is "GH". Sorry about that but I couldn't get that to show in the picture.
Old 05-17-14, 01:56 PM
Ok... thanks for the clarification
Furnace - Thermostat
GC = green = G
Y = yellow = Y1
W = white = W1
R = red = R
C = blue = C
Old 05-17-14, 01:57 PM
H
Also the C & Y wires there go out the AC unit.
Old 05-17-14, 02:15 PM
H
I re did the wiring to what you said and the thermostat doesn't turn on. Any ideas?
Old 05-17-14, 02:21 PM
Did you do the wiring with the furnace turned off ?
If not... you may have popped that 3A fuse next to the terminal strip.
Old 05-17-14, 02:34 PM
H
I did and I checked the fuse and its fine.
Old 05-17-14, 03:12 PM
Do you have a voltmeter that you can check for 24vac between the C and the R terminals ?
Old 05-17-14, 07:57 PM
H
I do but its not needed. Turns out there is a switch that has to be pushed in by the covers that go on the front of the unit for the power to go through the system. Thanks for your help!
Old 05-17-14, 08:01 PM
Ah yes..... the safety switch on the blower door.
