Wiring Nest Thermostat
Old 05-24-14, 04:41 AM
H
Hey! Just have a quick wiring question. Going to be hooking up a Nest Version 2 thermostat soon. I have a 2 stage heat pump system now with a Lennox T Stat. I took it off to look at the wires and see if the Nest was compatible. It looks all good. Here is the wires I have
O
R
Y1
W1
E
G
C
T(gray wire)
T(black wire)
my question is this: does anyone know where too hook the two T wires on the nest. That isn't even an option for a wire on their online help tool and I am lost. Thank you!!
Old 05-24-14, 11:38 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
The 2 T terminals are probably for an outdoor temperature sensor and should be taped off separately.
If you post the make and model number of the old stat we may be able to verify this.
Old 05-24-14, 03:42 PM
H
Thanks for the response! Right now I've a Lennox 51M37. With a heat pump. What do you mean by taped off? Like not used anymore
Old 05-24-14, 04:51 PM
Received 1,194 Votes on 1,105 Posts
Those two wires are indeed for an outside sensor. Your new thermostat does not use them so there will be no place to connect them. You just want to tape them lightly so they don't short to anything on the thermostat.
Old 05-24-14, 05:18 PM
H
Perfect thanks!! So should I not be worried about the outside temperature sensor not being used anymore? Or is it just not necessary now
Old 05-24-14, 05:22 PM
I think it's a great thing to have...... I'd be using it.
I wouldn't be using the nest as it can't use that sensor.
Now it's just not necessary.
