Switching Trane Thermostat to Honeywell WIFI--Wire help
Old 05-31-14, 10:48 AM
Kime Eubanks's Avatar
My Unit is a Trane Heat Pump model no: 4TWR4048A 1000AA
Thermostat Removing: Trane TCONT602AF22MAA (Also says TH6220D1051)
Thermostat Installing: Honeywell RTH9580WF1005
Was: R-R, Y-Y, Blue-B, O-O, G-G, W-W1, Black-Y2, Brown-F
What wires go where on Honeywell?
Old 05-31-14, 11:11 AM
Correction: Black was in X2
Old 05-31-14, 12:40 PM
Can you post a pic of the terminals on the new stat?
Old 05-31-14, 12:49 PM
Ignore the wires. I started and got confused.Name:  Honeywell Thermostat.jpg
Old 05-31-14, 02:19 PM
Old Trane Stat
This is how they looked on the old Trane stat
Name:  Old Trane Stat.jpg
Old 06-01-14, 07:28 AM
Try this, Red is ok, move Blue wire to C, Put Orange on W-O/B, Move white wire to W2. I can't tell what is landed on W2? Y is OK. Brown wire, is it labeled C?
Old 06-01-14, 11:33 AM
Received 1,509 Votes on 1,396 Posts
Should take care of you.
F = brown = tape off - not needed
X2 = black = may not be needed
W1 = white = W2-aux/e
G = green = G
O = orange = O
B = blue = C
Y = yellow = Y
R = red = R (leave jumper intact)
Old 06-09-14, 08:31 AM
Okay forget the last pic. I returned it and got a Honeywell Prestige THX9421R5021WW with Redlink. It just has two wires, R and C. I got R but which for C?
Old 06-09-14, 08:49 AM
You do realize that this thermostat requires an Equipment Interface Module to be installed at the equipment end...... correct ?
It's just two wires from the thermostat to the EIM.
Red = R
Blue = C
Old 06-09-14, 04:24 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
Looks like that number does not include the EIM but it does require it.
This model includes the EIM...
Honeywell Prestige YTHX9421R5085WW 2 Wire IAQ With Sensors - Programmable Household Thermostats - Amazon.com
