Replacing Thermostat Wiring! Single mom here!
Old 06-02-14, 12:10 AM
NewYellowLines's Avatar
Question Replacing Thermostat Wiring! Single mom here!
Hey all - I am trying to replace my old Weathertron thermostat with a new Honeywell thermostat. I have a heat pump with aux/emergency heat. I've taken photos of everything I can think of.
I can't figure out the wiring
Weathertron has: according to the old t-stat
W
G
Y
T
R
B
New Honeywell RTH3100C for Heat Pumps has:
E
AUX
Y
G
O
L
R
B
C
I'm a single mom, my home was built by Habitat for Humanity in 2005 - the heat pump is a Trane. I've been googling this for hours now and pretty frustrated.
Any thoughts? Thank you so much!
Old 06-02-14, 06:08 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
Trane=Honeywell
W= Aux and E
Y = Y
B = C
G =G
R = Rc and R
O=O (you didn't list this but your new stat is for heat pumps)
Tape off the old T wire.
Old 06-02-14, 06:26 AM
Here is a photo of the wall wires.
System is from 2005 but I suspect the t-stat is from before then. Habitat is famous for building spare parts houses.
The "T" wire is orange. Could T = O ?
Old 06-02-14, 08:47 AM
Ok - I figured out the wiring problem. I had to remove the old thermostat with... Force. I scraped off the O label from the plastic. There was never a T wire, it was the O wire all along.
This opens up a whole new can of worms though. I wired it all up and still nothing. I took the wire panel off the heat pump and saw a "5" orange automotive fuse blown. It was between the board and another device.
I think I may just need to replace this automotive looking fuse and I'll be good to go.
Thoughts? thank you!
Old 06-02-14, 09:54 AM
Yea if that fuse is blown nothing is going to happen. You can get them at any auto supply, I would buy 2 fuses, you never know.
Old 06-02-14, 01:23 PM
Houston204's Avatar
Posters often mistakenly connect Trane B to Honeywell B. This will pop the fuse. Trane's B is Honeywell's C. (24 volt common)
Forgetting to remove power to the air handler before replacing a thermostat can also pop a fuse.
Old 06-02-14, 08:55 PM
Thank you so much for all the help! My heat pump is humming away nicely! We are cool as cucumbers!
This forum is my new best friend!
