Trouble with Goodman HTP18-60 to honeywell RTH9580 wifi
Old 06-17-14, 05:56 AM
I am trying to upgrade my thermostat from a Goodman HTP18-60 to a honeywell RTH9580 wifi, I tried to follow the wiring instructions but it only ended up blowing hot air or it would say waiting for equipment so I put the old one back on. This is the wiring on my current thermostat
W2 and E are connected with a jumper
This is the new thermostat
Thanks for your help
Old 06-17-14, 08:37 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
You probably wired it correctly but forgot to configure function 170 to 7.
Old = New
C = C
Y = Y
G =G
O = O/B
W2 & E =AUX/E
R = R
Old 06-17-14, 10:44 AM
I'm not sure what you mean by function 170 to 7, I couldn't find it in the manual.
http://wifithermostat.com/Resources/Pdf/69-2809ES.pdf
And yes that was how I wired it.
Thanks
Old 06-17-14, 01:10 PM
Houston204's Avatar
Okay your stat is the retail model of their Prestige thermostat.
That model uses standard English instead of codes.
Configure it for heat pump operation . (page 24)
The reversing valve is energized to cool.
The auxiliary heat is usually electric but your aux heat can be something else.
That is an impressive thermostat.
I use the Prestige IAQ model which is very similar to that one but with a few more bells and whistles.
Old 06-18-14, 04:55 AM
I got it working, thanks for the advice.
