Will this thermostat work?
Old 07-08-14, 06:07 PM
Hi,
I have an old honeywell LR95329 that does not turn on the cold air unless I set the temperature really low (60). I imagine the mechanical thermostat coil is bust?
I would like to replace it with a programmable one.
This is an image of the wiring in the system I have right now:
Would it work if I replaced it with a basic Walmart one like the $24 Honeywell 5-2 Day Programmable Thermostat RTH2300B1012A?
It says "Does not work with heat pump systems with back-up heat, multi-stage heating/cooling systems and electric baseboard heat". I dont know what any of that means, is it possible to tell from the wiring on my old one?
My concern is the black wire X. I dont see this in use on the cheap Walmart one...?
Old 07-08-14, 06:17 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
No, you need a multistage heat pump thermostat.
Old 07-08-14, 06:25 PM
Houston204's Avatar
When you replace your thermostat this diagram should help...
Old 07-08-14, 07:45 PM
thanks. Hw can you tell that thats what I need? Because of the black wire?
Will this work?
http://www.amazon.com/Lux-TX500U-Uni...pr_product_top
Old 07-08-14, 08:31 PM
Houston204's Avatar
http://www.luxproducts.com/support/T..._WebManual.pdf
Yes that stat will work but I'd look at Honeywell.
You need a heat pump with Aux heat stat because you have the O wire to control a heat pump reversing valve. X and W control heat strips (Aux Heat)
I'd look at a Honeywell RTH6350.
Robot Check
The RTH6450 would add Autochangeover capability.
Th RTH7400 not require batteries.
The RTH7500 would not require batteries and give you autochangeover.
Old 07-09-14, 01:12 PM
Thanks for all your help.
I bought the RHT7600 from Home Depot
I must have wired something up wrong, because now when I set the temperature to a cooler temp, with cool mode on, I get heat blowing out ???
Any ideas what Ive done wrong?
Old 07-09-14, 03:19 PM
I would switch the the black and white wires. Make sure stat is set up for heat pump with back up.
Old 07-09-14, 05:37 PM
Houston204's Avatar
I would switch black and white as skaggsje has posted but the reason you are getting heat with a cooling demand is you need to set function 170 to 7 (Heat pump with Aux heat)
