2 heat 1 cool thermostat wiring problem
Old 07-20-14, 07:05 AM
Just installed new 1-stage a/c unit to existing (1 yr old) 2-stage furnace. Thermostat wiring guide (Honeywell FocusPro TH622) has diagrams for 2heat 2cool but not for 2heat 1cool except heat pump. This is just a gas furnace. Can existing thermostat be used, and how should everything be wired? Problem is that fan runs on low speed only, no matter how long the unit is on, and the cooling line is icing and can't keep up with even a few degrees of heat.
Thanks
Old 07-20-14, 08:08 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
Configure the stat for 2 heat 2 cool.
Thermostat Y1 must connect to furnace Y2 (the higher stage Y) to run the correct fan speed with single stage cool two stage heat applications.
Post your furnace make and model number.
Is the air filter and evaporator coil clean?
