Need advice on wiring new thermostat
Old 07-21-14, 07:00 AM
C
Got a new single stage thermostat. The new thermostat is Rc Rh C W Y G O B my old one is wired like this.
White wire: W1
Blue wire: W2
Green wire: G
Red wire: Rc jumped to Rh
Yellow wire: Y1
I have gas furnace and electric heat. I know this won't run both just want the gas furnace to work and air conditioner. Thanks the thermostat is a white Rodgers.
Old 07-21-14, 09:03 AM
Looks like your new stat is for a heat pump. You can probably get this to work but you will have to use the blue wire as common (C) in the new stat. Then remove blue wire in furnace and move it to the common side of the transformer.
Old 07-21-14, 10:35 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
What is the make and model of the furnace and new stat?
Old 07-21-14, 10:50 AM
C
It is an amana furnace I will have to look at the model when I get home
White Rodgers 1F86-344 80-Series Non-Programmable Single stage
