C wire on new WiFi Honeywell T-stat
Old 07-26-14, 12:45 AM
Z
Question C wire on new WiFi Honeywell T-stat
So, like so many others I've seen, I bought a new tstat and I don't have the C wire.
However, I found this wonderful video from Honeywell stating that I can just use the G wire, lose control of my independent fan controls, but still get by. Great! So I plant the G wire into the C terminal and head down stairs to do the same thing on the terminal block. However, there's already a red wire terminated to the C terminal.
The Red wire in C is bundled with a yellow wire and going to the back of this thing, which is mounted to my Furnace.
For what it's worth, here's a diagram of the terminal block
Old 07-26-14, 01:15 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
That video does not have a 2 transformer system.
Post some pics of the condenser wiring outside.
Old 07-26-14, 06:47 AM
Z
Thanks for responding
Old 07-26-14, 07:31 AM
Houston204's Avatar
I see high voltage wiring in your pics. Can you take some pics from further back at the indoor and outdoor unit?
Does that Rc wire run to a transformer at your outdoor unit?
Are you using more than 2 low voltage wires from the house to the outdoor unit?
We need to find out more information on your RH and RC wires.
Your contactor outside looks bad.
Old 07-26-14, 08:42 AM
Received 1,525 Votes on 1,408 Posts
There are wire colors that appear at the thermostat but not at the fan center. The thermostat wiring may be spliced or doesn't go to where you are showing us.
