Wiring Help: Honeywell Wifi Thermostat
Old 09-07-14, 11:14 AM
So I just picked up a Honeywell Wifi RTH9590 and tried to install it but I am completly stuck and thinking I might have to return it.
So my current setup is just heating. I have oil / baseboard. The wires coming up from the boiler is just 2 wires, RH and W.
Here is a pic from the heaters control panel
The instructions for this unit clearly state I need a C wire. Well I am only trying to use this for heat, as I have a in wall AC unit.
Anyway to make this work? Please help
Old 09-07-14, 01:25 PM
firedawgsatx's Avatar
Received 2 Votes on 2 Posts
Here is a link to a recent thread that discusses how you may be able to install an external 24V transformer to supply power for the C terminal on your new thermostat:
http://www.doityourself.com/forum/ai...ansformer.html
Here is a link to a manual: http://pdf.lowes.com/useandcareguide...890762_use.pdf
Looking at the instructions for alternate wiring on pages 16-17 it seems like it should be relatively easy to do with an external transformer.
What type of thermostat are you using currently?
Old 09-07-14, 01:46 PM
Received 2,955 Votes on 2,666 Posts
Welcome to the forums.
There may be a C connection at that Honeywell control but we'd need a larger pic of the whole thing and the part number. It would be LA-XXXX
You would still need a third wire to the thermostat from that area.
If you choose to use a separate power supply to run the thermostat - you could use any 24vac 20watt unit.
24vac transformer power supply | eBay
Old 09-08-14, 05:19 PM
Geochurchi's Avatar
Received 154 Votes on 140 Posts
Can you fish a wire from the boiler to the Tstat location ,maybe using the existing cable as a pull string,if so post a pic of your boiler controls,the best way is to use the existing transformer on the boiler.
Geo
