Honeywell thermostat installation with zone control panel
Old 09-08-14, 11:25 PM
I
just bought a new wifi honeywell thermostat to replace old round honeywell thermostat. although I read some online info, still got confused a little bit.
here are some background.
furnace is lennox pulse 21 -- model G2104/5-100-1.
old round honeywell thermostat only has 2 wires(r & w) attached. once I removed it from the wall, I found 2 more wires(b & g) behind the wall, not used.
there is a switch in the furnace room to control the switch including heat-off-fan-cool.
in furnace control panel, there are 5 terminals for wires (from left to right) R, W, Y, G, C. 4 connected wires are r, w, g, b. the connection are R-r, W-w, G-g, C-b. Y terminal is vacant.
new wifi honeywell thermostat has RC-R, W, Y, G, C for conventional.
here are my questions:
how to deal w/ the control switch in furnace room? if I just change the thermostat, will the new one take over the control function? for wire connection in new thermostat, should I just use the same pattern in the furnace control panel?
thanks for any suggestions.
Old 09-10-14, 06:06 PM
Houston204's Avatar
Received 38 Votes on 34 Posts
http://www.hvacpartsshop.com/manuals/G21_Series.pdf
Is the control switch in the furnace room something that someone added after the installation?
I see no mention of it in the manual.
I'd lose the field added controls and wire the stat wires to the furnace.
Name:  Lennox G21 terminals.jpg
Old 09-12-14, 07:11 PM
I
Thanks for the reply.
I just got a furnace tune-up today. The technician took a look at my furnace system and revealed more info for me.
The previous owner installed a zone-system with furnace. There is a zone panel--MasterTrol Mark V, model mabs-V-3 to control 2 zones(upstairs and downstairs) in the house. Somehow, they deactivate the downstairs zone control and only activate upstairs zone. So only the upstairs thermostat works. The control switch in the furnace room also connects the zone panel. The technician also got confused whether the thermostat upstairs will stop the furnace or not when it reaches the target temperature. He mentioned that we will need a lot wiring work if we want to skip the zone panel.
I will upload a few pictures later.
Old 09-14-14, 05:47 AM
Houston204's Avatar
https://customer.honeywell.com/resou...0s/68-0112.pdf
The motorized dampers are the first thing to fail. We are going to need to locate theses as well to verify operation. Do you have a volt meter?
Old 09-14-14, 01:50 PM
I
here are several pictures
Old 09-14-14, 04:06 PM
Received 2,951 Votes on 2,663 Posts
That connection is awfully close.....
Old 10-09-14, 03:43 AM
I
possible HVAC Selector Wiring Solution?
Based on my observation, zone dampers are all deactivated. Zone 1(upper lever) is on, Zone 2(basement) is off. Upper lever has a round honeywell thermostat T87F with only Red & White wire connected. Although there are 4 wires available. I think this T-stat has no control to the furnace.
I am trying to install a programmable T-stat to replace the old honeywell one. Because of the zone controller and extra selector unit, I am confused about its wiring. If anyone can give me some suggestions where I should begin to work with, that will be much helpful.
Old 10-09-14, 07:48 AM
You started a new thread when you already had one started on the same subject.
You had a technician there to look at your system. You may have to have him handle this wiring as it is very involved.
