Old Lennox Mercury thermostat to Nest conversion help
Old 09-10-14, 01:31 PM
P
Hi all. Iím a new homeowner of a 1970ís-ish house. I am looking to replace an original (I think) Lennox Legend mercury thermostat, with a new Nest thermostat. As you may have guessed, the letters and color codes do not match! I'm hoping that someone can help me with the conversion. Here is what I have noted for the old Lennox thermostat:
Model#: 66F0001 (on sub-base)
65F9901 (on base)
Letter:Wire Color
VR:Red
V:Bare
X:White
M:White
L:Empty
F:Blue
R:Green
M2:Green
E:Empty
Y:Blue & Red (two wires attached here)
A:Red
On the Nest, the letters offered are
Y1
Y2
G
OB
Rc
W1
W2 (aux)
C
RH
Would any one be able to help me cross-reference these letters? Thanks in advance. Iíve enclosed a pic as well.
JP
Old 09-10-14, 05:38 PM
Received 2,946 Votes on 2,659 Posts
Welcome to the forums.
This is going to be a little tricky. Normally an 8 wire cable would be run..... not two 4 wire cables with the same exact colors.
What kind of system do you have there ?
Heatpump ?
Electric reheats ?
Gas reheat ?
Gas furnace with regular A/C ?
Old 09-10-14, 05:54 PM
Houston204's Avatar
Received 38 Votes on 34 Posts
Old = New
VR:Red = R
V:Bare
X:White = C
M:White = Y
L:Empty
F:Blue = G
R:Green = O
M2:Green = Y2
E:Empty
Y:Blue & Red (two wires attached here) = Aux
A:Red = Tape off
PJ you are welcome to copy this pic and use it when needed.
Old 09-10-14, 08:55 PM
P
Thanks for your response PJmax, I believe Houston204 has replied as well, but for what it's worth...I believe it's regular central A/C & heat.
Old 09-10-14, 08:58 PM
P
Thanks Houston204 - one more question..
Thanks Houston204 for your reply. I appreciate it. Does "R" from VR:Red=R correspond to RC or RH on the Nest?
Thanks again. JP
Old 09-10-14, 08:59 PM
So be sure to ID the wires since you have two sets of the same color.
Rh should be fine.
Old 09-10-14, 09:43 PM
Houston204's Avatar
That is a heat pump thermostat with a 2 stage outdoor unit and auxiliary heat.
Yep, connect the old VR to the new RH
Old 09-11-14, 06:47 AM
P
Thank you both. It's great to have this type of forum for these handyman jobs!
JP
