Thermostat wiring (Robertshaw 9520 - Arcoaire EBP1800B)
Old 09-15-14, 04:26 PM
I have a robertshaw 9520 thermostat and an Arcoaire furnace:
Serial Number A030950302, Model: EBP4800B.
the house in which the unit is installed was vandalized ie outside unit, thermostat wire, all wiring was stolen... any help will be greatly appreciated in how to rewire the thermo back to the furnace. the furnace has only 4 wires red, brown, grey, and white. I have no outside unit yet so all I need is to get the furnace working!!!!!
Old 09-15-14, 07:20 PM
Received 2,813 Votes on 2,545 Posts
Welcome to the forums.
We're going to need the colors/terminals off your thermostat.
Actually the electric furnace part should still be working along with the fan. Have you tired it ?
The following picture is the basic wiring. You may have wiring connected at this location and going to the missing outside unit. Make sure that wiring is insulated outside or disconnected for now.
At the present time you are only concerned with the R, G and W's.
Link to your manual for more info if needed.
Manage my life EBP manual INSTL L0502489.pdf
Old 09-16-14, 07:21 AM
D
Received 1 Vote on 1 Post
Old 09-16-14, 07:31 AM
I truly appreciate your help! all wiring to thermostat and furnace were missing, so I have nothing to reference my wiring to. I've included a pic of the lugs on the RobertShaw 9520 thermostat.
Name:  RobertShaw 9520 Thermostat wiring lugs.jpg
Old 09-16-14, 07:34 AM
If the wiring from the thermostat to the furnace is missing then the first step is to install a piece of 8 conductor thermostat cable between them.
Second step is to locate a screwdriver that will fit those t'stat screws.
Old 09-16-14, 07:40 AM
all that has been done.
thank you
Old 09-16-14, 08:07 AM
To all that has read and replied to this thread, I greatly appreciate all help! Iím not a dummy; I have no prior knowledge of any HVAC. I donít want to make a mistake wiring and damage the furnace and I canít afford to hire a professional to wire the thermostat! Again I greatly appreciate all help!!!
Old 09-16-14, 08:20 AM
firedawgsatx's Avatar
Received 2 Votes on 2 Posts
I have attached a wiring diagram that should get you going for heat. Turn off power to the unit when installing wires. The letters to the right of the photo are the connections at your fan coil.
Old 09-16-14, 08:34 AM
I had the red and grey but wasn't sure about the white... Thank you so much!!!!!
Old 09-16-14, 08:38 AM
Let us know how it works out or if more assistance is required. Your thermostat appears to be a non-programmable thermostat for a 2-heat/2-cool heat pump application. Since it is non-programmable, it may be a good idea to swap your thermostat for one that works for a conventional system since you are only using it for heat at this time. If you decide to install a heat pump later on then you could use the 9520.
Old 09-16-14, 03:29 PM
Unit working!
Unit is working!!!
Thanks to all for helping!!!
Old 09-16-14, 03:47 PM
Glad you got it goin' and thanks for the update.
