Programming Vision Pro 8000 for stage 2 and 3 to work in unison.
Old 11-01-14, 06:41 PM
U
I can not program the Honeywell TH 8320U1008 so that it will make stage 2 and 3 (emrgency heat) to be on at the same time. So if the heat pump can not give me enough heat, I want the heat pump stage 2 on and with stade 3 on. How can I do it???.
Old 11-01-14, 06:50 PM
Received 1,510 Votes on 1,397 Posts
Welcome to the forums.
My strong point is wiring..... not programming. Hang tight... the forum pro, Houston, will be able to help you out.
Old 11-01-14, 07:19 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
I have been told by instructors at Trane classes that the VisionPro will use E as stage 1 emergency heat and Aux as stage 2 emergency heat on models that have separate Aux and E terminals.
A clampon amp meter on a heat strip leg or a digital thermometer in the supply duct would help prove this.
Old 11-02-14, 05:05 AM
U
Thanks for anserwing, the wiring AUX and E are on the same screw, they are not on 2 borns.
Old 11-02-14, 05:11 AM
U
Thanks for anserwing, the wiring AUX and E are on the same screw, they are not on 2 terminals.
