Mercury to Digital (Z-Wave) Wiring.
Old 11-06-14, 07:56 PM
H
Hi all. Any assistance would be appreciated!
I'm swapping out an old Rheem Mercury Thermostat controller for a 2GIG CT100 (z-wave) thermostat.
This is for a Heat Pump w/electric aux heat system.
The Rheem mercury t-stat had 7 wires connected:
W2
L
B
X
G
R
Y
The O and E connectors on the t-stat had nothing connected to them (there is a O wire, but it was not connected to anything.)
Here is a picture of the old thermostat connections:
I have currently hooked up the following connections to the CT100 (OLD/NEW):
G/G
Y/Y
R/RH (jumpered to RC)
B/B
X/C
W2/W2
That means that I am still not using the O wire. I'm pretty sure that's correct.
I'm also pretty sure that using the X for my "common" wire (which I need for z-wave) is correct.
But what I'm most worried about having done correctly is the W2 and L wires.
Should my old W2 wire be plugged into the new W instead of W2?
And what about the old L (black) wire? I don't know what to do with it.
Thanks for looking!
Old 11-06-14, 08:22 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
Welcome to this forum.
It looks like the old W2 is now W according to your manual.
G/G
Y/Y
B/B
X/C
W2/W
Name:  CT100 heat pump.jpg
Old 11-06-14, 08:40 PM
H
Thanks for the response.
I'll move the old W2 to the new W. It didn't seem right that I would have something in the new W2 but not the new W... but I wasn't sure if there was some legacy W2 spec that required that's where it be since that's all the old T-stat had.
What about that old L (black) wire? I'm not sure what it does or what I should do with it. Is it the manual Em Heat switch? Do I not need that with the new thermostat?
Old 11-06-14, 09:14 PM
Houston204's Avatar
L is for Light.
Some outdoor units will give you a trouble light.
Tape it off since your new stat doesn't support it.
