Help with Honeywell t-stat wiring, when converting to Nest
Old 11-10-14, 06:10 PM
Hello, hoping you can help. I'm trying to convert Honeywell Chronotherm t-stat to Nest, and am confused about the wiring. The boiler is an old honeywell, and I attach three pictures of the upstairs t-stat wiring, and the downstairs t-stat wiring and boiler plate.
My confusion stems from there seemingly being two C wires (green and blue both have 'C' next to them), and yet only one C wire input on my Nest t-stat. And yet downstairs, it would appear that blue is C and green is R, and yet upstairs the white wire goes into R. Very confusing to me!
Ultimately, I'd like to know which wires on my honeywell t-stat should go into which inputs on my Nest?
Thanks
Simon
Size:  48.0 KBName:  20141110_205550.jpg
Size:  38.9 KBName:  20141110_205452.jpg
Old 11-10-14, 06:54 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
Wow, that is a very old Chronotherm.
Rc = green
C = blue
Rh = white
W = red
The old C and C powered the clock.
If your Nest doesn't like the heating circuit swap red and white (T and T on the boiler).
Old 11-11-14, 09:23 AM
Yes, that worked perfectly - thank you!
