Lennox 36G7001 replacement with Honeywell RTH6450
Old 11-15-14, 07:37 AM
R
I thought this would be easy! Not so easy after all.
I have a heat pump system and the connections are
R
V
F
Y
E (unused)
X
The Honeywell has RC R Y O/B G AUX/E L
By looking at a few online posts my best guess is
R to OB
V to R
F to G
M to Y
Y to AUX/E
E (unused)
X to AUX/E
Can anyone set me straight?
Thanks for your help!
Old 11-15-14, 08:07 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
You almost had it.
The old X is 24 volt common.
Your new stat does not use this wire, so you can tape it off .
Old 11-15-14, 09:09 AM
Houston204's Avatar
Remember to turn off the breaker to the indoor unit (or package unit) before replacing the stat to avoid the risk of popping a fuse or cooking a transformer.
Old 11-15-14, 09:29 AM
R
Thanks a lot - I'll try it like that!
