Need help with thermostat wiring
Old 11-29-14, 11:51 AM
L
Hi,
I am installing a LUX thermostat to replace my old York thermostat.
My old one had the following wires:
W- white
B- blue
G-green
R- red
x-brown
o-orange
y- yellow
new one has the following:
O
B
(it says use only O OR B, not both)
G
Y (jumped to W)
RC (jumped to RH)
W2
C
I installed the Orange wire into O, left the blue wire free to be taped off and installed the brown into C. Is that correct?
Thank you!
Old 11-29-14, 12:39 PM
On some of the old stats B is your common, So I would land the blue wire on C of the new stat. X- brown I would tape off. Do you have back up heat in your furnace?
Old 11-29-14, 01:13 PM
L
Yes, there is back up heat, we have a heat pump. In the manual for the new thermostat it said x or b might be the common
Appreciate the help!
Old 11-29-14, 01:44 PM
Received 1,510 Votes on 1,397 Posts
Welcome to the forums.
With York.... it looks like X or B could have been used for Common. I'd also lean towards B as being the C and tape off X.
A model number of the stat would be needed for further help.
Old 11-30-14, 05:32 PM
L
That worked, thank you! I appreciate it
