Tekmar 363 morning boost
Tekmar 363 has Mix BST and Boil BST which provide "morning boost". But I cannot see that it has a clock or that you can set time. When does the morning boost occur? What triggers it to occur? Thank you.
The morning boost would be in the " Occupied and Unoccupied" mode. You will have to input what time to start the boost. The boost occurs when you have set up the "occupied and unoccupied" times, AKA night setback.
Thank you.
But it appears we have no clock, no timer, in the 363 or in the setup. Just a manual Occ / UnOcc switch. So appears we will get the boost just when we manually hit UnOcc to Occ.
Set the middle DIP switch in the up position. Then you will have access to morning boost. Check out page 22 in the manual.
Turns out "morning boost" needs a timer and we do not have one so...
If "morning boost" is on, we get it only when we change the manual switch from UnOcc to Occ.
