Need help wiring a 2nd Generation Nest
Old 12-02-14, 10:30 PM
T
Good evening
I have a Lennox ml193uh and i am trying to wire a nest thermostat.
My troubles are how to wire a common to the nest so it does not loose power. I have been reading about wiring the c to a 24v common source. I do not know where to pull that power from the board on the furnace.
Thanks in advance.
Turbopeq
Old 12-02-14, 10:40 PM
Received 1,528 Votes on 1,411 Posts
Welcome to the forums.
Do you know where the control board is ? It may be in the lower section of the furnace with the blower. The pic below is what you should see. The C terminal is clearly marked next to the R, W, Y and G.
