Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Programmable replacement for non-programmable Honeywell 69-1490 thermostat
Old 12-08-14, 07:04 AM
We currently have this thermostat in a room with hot water radiators heated by a natural gas boiler that does the whole house. When installing these radiators in a side porch we wanted a separate zone because it is colder than the rest of the house. We now want the heat only thermostat to be programmable although only night/day ideally is needed. One restriction is that we only have a narrow space (about 4.5") so it would need to be a vertical kind. Thanks for any suggestions. There are so many thermostats out there that it becomes mind boggling.
Old 12-16-14, 09:32 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
The Honeywell RTH221B is an option you might consider...
Name:  Hon TH2110D1009.jpg
Old 12-17-14, 08:59 AM
Thanks very much for this suggestion. We just went to the store and couldn't get this one (out of stock at our local store) but got another a bit more expensive the same shape but with a bit more than we wanted re programming but OK.
