McQuay
Old 12-16-14, 09:44 AM
McQuay
Hi Guys,
I have a 20 Ton Mcquay RTU heat and cool that uses the dual slider proportional thermostat as pictured. I am trying to replace it with a honeywell "Traditional" wifi thermostat but getting caugh up on the H/C Max, H/C Min wires in the slider tstat. Is their any way to use the traditional thermostat with this unit.
Current Tstat wires
1. Red H/C Max
2. Green H/C Min
3. Blue Cooling
4. White Heat
5. Brown Temp sensor wire1
6. Black Temp sensor wire2
Thanks!!
Size:  19.4 KBName:  image2.jpg
Size:  36.5 KBName:  image3.jpg
Size:  25.8 KBName:  image4.jpg
Old 12-16-14, 10:09 AM
Received 1,530 Votes on 1,413 Posts
Welcome to the forums.
You can't just put that thermostat on the existing wiring. I'm not a pro on McQuay systems but there may be a way of using that thermostat if there is some type of communications board that can be removed. A full model number of the unit would be helpful.
Old 12-16-14, 10:12 AM
665404B-09 is the model number of the proportionate tstat, the new honeywell is RET97E5D.
thx.
Old 12-16-14, 10:15 AM
With proportionate, the higher the voltage the more heat it would send which makes me think if I send the full 5v back up the line, why don’t it assume I want full heat…. Lol
I don’t need a sliding scale for heat. I can give it the full 5volts on the line and it sends me all the heat. Well it should in theory anyway. Unless it also needs to see a balanced voltage on the cooling side at the same time as well…
Old 12-16-14, 10:19 AM
Theoretically I should be able to tie H/C Max to heat for full heat or to cooling for full cooling and not use H/C Min. but idk… I think more is happening under the hood lol
Old 12-16-14, 08:59 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
You would probably need to use relays to install a conventional stat.
What is the model number of the air handler or package unit?
Old 12-17-14, 05:14 AM
Geochurchi's Avatar
Received 91 Votes on 86 Posts
Hi, I don't believe that stat is even compatible with the McQuay system the honeywell requires different a different voltage, doesn't vary voltages as required by MqQuay.McQuay has there own little nitch.
Geo
