WiFi thermostat - help with C wire
Old 12-27-14, 01:08 PM
I have a similar problem. Purchased a new WIFI thermostat that requires the "C" wire for 24V power to the thermostat. I only have the red (RH) wire and White (W) wire. I was wondering since the red wire is a 24V feed, can that be jumped to the "C" connector and use it to power the thermostat? Or if I have to run another wire (which is not a problem) where would I hook it to on my Trane XL80 furnace?
Old 12-27-14, 01:37 PM
Received 1,525 Votes on 1,408 Posts
Welcome to the forums.
As promised... a new thread.
James... if you go to your air handler.... you should find a C connection with your existing wiring. You can shoot us a pic or supply the full model number of your XL80.
Old 12-27-14, 01:50 PM
Hopefully the pictures came through.
My furnace is a Trane XL80 - TUD090A936A0
Tstat is a Honeywell RTH6580WF
Both Tstat wires are hooked to a transformer in the furnace (pictured). Not to the control panel.
Old 12-27-14, 04:01 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
You cannot jumper R to C.
Do you have a third wire in the brown jacket of your existing stat wire?
The fan center pic is a bit distant.
Old 12-27-14, 04:50 PM
On that same transformer you should see a W, R, G, Y and C screw terminals. You need to run a new cable and use the C terminal.
Old 12-27-14, 04:59 PM
OK, I ran another set of two wires through the wall. I will look for the "C" terminal on the transformer.
Thank you.
I'll let you know if I find it.
Old 12-27-14, 05:07 PM
Ok, so on the transformer there are the following.
W and R which we know about
The post across from W is Y
The center post is G
The post across from R is B
That is all 5 posts.
I read somewhere that Trane uses B as the common. If this is the case, then I should hook to B?
Old 12-27-14, 05:11 PM
This is the post I was referring to.
firedawgsatx's Avatar
firedawgsatx
firedawgsatx is online now Member
Join Date
Jul 2013
State
TX
Posts
1,607
Welcome to the forum!! Yes, you should be able to wire it as you propose. A Trane/American Standard system is different from others as the B terminal is the common. Make sure you turn off power to the air handler and the hydronic furnace before moving the wires. I suggest you try the set-up on your old stat before wiring up the new one. On your new stat don't forget to remove the jumper between R and RH before wiring it up.
Read more: http://www.doityourself.com/forum/th...#ixzz3N9OuNRnc
Old 12-27-14, 05:19 PM
Do you have a meter where you can check from B to R. I don't recall ever seeing a B on a basic Honeywell fan relay center.
Old 12-27-14, 05:22 PM
Yes, I should bet 24VAC right?
Old 12-27-14, 05:25 PM
I get 27.7 VAC actually.
So this looks like it is correct.
Old 12-27-14, 05:27 PM
Houston204's Avatar
Trane's B is 24 volt common. This is C on almost every other brand.
Old 12-27-14, 05:29 PM
Ok, going to hook it up that way, B on furnace to C on Tstat. I'll let you know how it works.
Old 12-27-14, 05:54 PM
Ok, looks like this worked great!!
Thanks for all the help!!
So that would be a custom Honeywell fan center as the replacement for it doesn't show a B terminal.
Old 12-27-14, 05:55 PM
Great news. Good job.
