Wiring an Ecobee thermostat on Lennox system.
Old 01-09-15, 04:33 PM
L
My system is Lennox with heat pump. On old thermostat the wiring is Brown wire goes to C, red to R, white to E with jumper to W2, yellow to Y, green to G, blue to O/B. I thought Lennox uses orange for O/B and is supposed to be set for "O". How should I wire up the new ecobee thermostat and what setting do I pick for O/B?? Fyi old thermostat was a white-Rodgers. Air handler and compressor unit are Lennox.
Separated from... http://www.doityourself.com/forum/th...-pictures.html
Old 01-09-15, 04:56 PM
Received 1,530 Votes on 1,413 Posts
Welcome to the forums.
We try to keep one poster in a thread to eliminate confusion.
We usually like to have picture of old stat and wiring or make and model of old and new thermostats.
C=brown
R=red
E & W2=white
Y=yellow
G=green
O/B=blue
You didn't have an orange to use for O/B.
Usually the brown would be used for O/B and the blue would be used for C.
Not every installer follows the industry standard color code.
Old 01-09-15, 05:52 PM
L
The C wire is definitely brown, I confirmed with the connection on the compressor end. The blue wire is going to the O/B terminal. White Rodgers was 1f89-211. New tstat is ecobee 3.
