lux psp511lca and taco 571-2
Old 01-13-15, 05:19 PM
T
lux psp511lca and taco 571-2 Solved thanks!
Hello, I bought this new lux tstat because I wanted to be able to adjust the temp swing on the thermostat. My honeywell short cycles my boiler frequently.
The Lux manual says it cannot be used with 3 wire zone vales. Is this taco a 3 wire?
THanks
Old 01-13-15, 05:38 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
No, that is not a power open / power closed valve.
A Johnson VA7150 would be an example of a power open/ power closed valve actuator. That stat would require an additional relay for a 3 wire power open / power closed valve but you are good...
Old 01-13-15, 05:41 PM
T
Thank you. I will install this tonight. I saw those three screws on the valve and thought it was 3 wire, but then see two at my existing tstat so I got confused. Thank you very much.
Old 01-13-15, 05:52 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
What type of Honeywell were you using?what makes you think it is the Tstat?
Geo
Old 01-14-15, 07:32 AM
T
rth2310b
Its in my bedroom and I hear it click on or off quite frequently.
Old 01-14-15, 08:58 AM
Geochurchi's Avatar
How long had this been going on? Have you tried new batteries?
Geo
Old 01-14-15, 09:26 AM
N
I just installed a Lux stat for the same "swing" feature last night. What I didn't realize is that the swing applies to both side of the set temp, so if I set it to 68 with a 1* swing, it turns on at 67, and off at 69.
