Taco SR 503 wiring option for 2nd thermostat
Old 02-02-15, 03:56 PM
Is there a way to connect a 2nd thermostat to a Taco SR 503 that will activate a 120v zone pump without turning on the boiler? This is for a small in floor heating loop that will draw from the hot water tank to minimize boiler on time.
http://www.taco-hvac.com/uploads/Fil...503102-083.pdf
I currently have 1 zone for water radiator heaters and a residential hot water reserve tank on priority.
Thanks
Old 02-03-15, 09:13 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Hi Jeremy & welcome. I don't think there is a way to prevent the boiler from firing but why would you want to?
If the floor heat zone calls for heat & cools off the hot water tank, you won't have heat to put into the floor.
Isn't the tank temperature controlled by it's own thermostat/aquastat?
How about some pictures of the current set-up?
Old 02-03-15, 02:35 PM
Currently when the floor loop calls for heat, the boiler will run continually. My thinking was that if I used a hot water reserve looping the return back into the hot water tank it may give the boiler a break. My hot water tank does have an aquastat and will call for heat from the boiler when required. Is my logic completely incorrect?
Old 02-03-15, 03:28 PM
Grady's Avatar
Indrect tanks are often used as buffer tanks for in floor heating. Another benefit is you can better control the temperature of the water going to the flloor loop. I don't know of any way to run the loop circ off of the 503 without firing the boiler. I suggest using a simple switching relay such as a Honeywell RA-89A & allowing the tank's aquastat to control the tank temperature & thus the firing of the boiler.
Can you provide some pictures of your current set-up?
