Heat pump thermostat wiring
Old 02-05-15, 04:25 PM
R
Before and after pic look right? the black wire is brown on the new
Separated from... http://www.doityourself.com/forum/th...ec-strips.html
Old 02-05-15, 06:29 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Looks good.
You must also configure the new stat to match your system.
Heat pump with Aux heat.
The O/B terminal is O so it is energized to cool.
I take it that you do not have an RTH6350 since your new diagram has a C terminal.
