Installing a TrueIAQ wth Nest
Old 03-07-15, 06:34 AM
R
I've got an American Standard Freedom 90vs furnace with a Honeywell HE150 Humidifier and a Nest thermostat. It has been extremely cold the last couple of winters and I have been having condensation issues so I bought a Honeywell TrueIAQ humidistat to automatically adjust humidity. My initial problem seems to be drawing power to the IAQ in that my furnace connections do not have a connector labeled "C" which seems odd. If I take power from the "power out" from the Humidifier then the humidistat only lights up when the furnace is running. My furnace connectors are labeled G W2 W1 B O Y YLO BK R.
Where is the C for the Humidistat?
Old 03-07-15, 09:11 AM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
American Standard and Trane label the C terminal B on their equipment.
Old 03-07-15, 09:29 AM
R
OK, that helps immensely!
I'll come back if there are problems!
Thank you!
